how to control the gain/sensitivity in the following schematic?
http://www.hobbykit.eu/sch/s1035.gif
I thought it is R2 (1M) but it is biasing resistor, not a feedback like in opamp.
So, is it the R1 (4k7), load resistor for the fet transistor inside the electret mic capsule?
Best Regards
Best Regards
One way would be to replace R3 with a pot and connect C3 to the wiper
Generally if the mic is a two wire then R1 is external, three wire then internal.
Find the data sheet for your particular mic...or get one that you can find a data sheet for. (IMO)
Not all piezo mics have the same supply and load resistance requirements.
