Electra Print 6BX7 SE/PP Schematics
Hello--
I've got a few ANK and Bottlehead kits under my belt and want to attempt to go from a schematic to a build.
For various reasons, I am attracted to this Electra Print 6BX7 SE or PP schematic:
Electra-Print.com 6BX7 SE Amplifier
I have started to attempt to translate the schematic into a design (on a sheet of paper), but the thing I don't quite understand is how to make this into a stereo amplifier.
Is it as simple as duplicating the top half of the schematic? If so, then this would mean that the rectified DC from the TX would simply fork, one path leading to the L channel circuit, the other leading to the R channel circuit?
Thank you for your time,
K
No. If you want stereo, you will have to beef up (redesign) the power supply so it can provide twice the currents. Both the B+ and the heaters. If you want to build it as dual mono, then you make 2 of everything shown.
