EL84 safe plate voltages
I did some tests on a 1Khz sine wave, and it lies around 12W for min volume and 13W on max. So if I connected it to my grid, it would be 13,5-14,5W.
Alan4411: It's a Lafayette LA-224B. Produced in Japan, ca 1965. Apparently it was not amongst the most expensive amplifiers, but I think it's gorgeous :scratch2:
In which case I would not worry about the EL84s being 'over run' or the mains transformer unduly.
Have a look at the schematic, the transformer is rated at 230 volts AC and the HT+ (B+) is quoted at 300 volts.
As it's 50+ years old and Japanese I would be more worried about the original grey 0.05uF coupling caps going leaky and that will damage the EL84s...
I've replaced all the caps, ceramics included. It's fit for fight and sounds nice 🙂
I see 230V in the schematic, but unit seems to say otherwise. I've attached a picture of the transformer. Could it be that it actually is a 230V unit, pretending to be 220V? 😕
With the lid off, at 220V, transformer shell stabilized at about 65C in the hottest areas.
