Thanks,
I can order Hammond without any problems from Mousre which I will be doing for their PSU at least
20to20, I agree. Hammond is a good one to try shipping to the UK, or finding a distributor there.
eldarvanyar, Hammond is in Canada.
Hopefully some company knows how to get the transformers from Canada to UK.
Perhaps there is a Hammond distributor in the UK.
EL84 Push Pull, right?
Hammonds made for PP EL84:
10 Watts, 8k plate to plate, with Ultra Linear taps, to 4, 8, and 16 Ohms. You can try Pentode mode, Ultra Linear mode, and Triode mode, all on the same transformer.
10 Watts, 10k plate to plate, with Ultra Linear taps, to 4, 8, and 16 Ohms. You can try Pentode mode, Ultra Linear mode, and Triode mode, all on the same transformer.
I recommend purchasing at least 1 to try, build it on a board, and see what you think.
I have one of those 10k plate to plate Hammonds.
I build low power push pull amplifiers in Ultra Linear mode.
I do not run the tubes at more than about 10 Watts per plate dissipation.
I have used that transformer with KT66, KT77, and 6L6GC.
Using a similar 10Watt, 10k plate to plate Ultra Linear transformer from Edcor, I built a similar amplifier with 7591 tubes.
It is in the Tubes / Valves Threads. it is called:
" A Simple Low Power 7591 Push Pull Amplifier "
Click and paste the title above into this forum's Search Forums Box, and you will find that Thread.
It may not be your 'cup of tea', but it is food for thought.
Someday, If I ever get the time, energy and desire, I will do some measurements of that 7591 amp, and post the results on that thread.
Maybe look for Z-565 Dynaco OPT's as they can be had as clones and are well regarded sonically likely as they have the proper interleaving. They also have the proper 25% UL taps if needed.
The originals have 8 & 16 ohms outputs and the clones can be had in 4 & 8ohms.
Thanks,
check hammond quality. have several power transformers that have developed a buzz in their end bells. hammond was of no use in solving the issue.
