EL84 ECC83 SE Amp schematic
All the really old designs are specified for input signals considerably less than 1V (0.2V would be typical) and the modern sources typically have 1-2V signals. This means that a modern design needs typically 1/10th the input signal. The mullard 3-3 will have excessive gain with a CD/DVD source and will need input attenuation to make them match. For me this is simply a bad approach.
Shoog
Hi Shoog
Thanks for the reply
Yes that makes sense the old design
Being unstable for DVD or cd input
I am now thinking of using the schematic
You posted earlier with the 6N3P
The 6n3p seems easy to obtain
Or I have also looked at the RH84 version 2
Thanks again
