WARNING: Tube/Valve amplifiers use potentially LETHAL HIGH VOLTAGES.
I don't use superglue anymore because it easily breaks while inserting the tube in the socket. A little bit of elasticity is needed. It is best to avoid excessive glue, the glass evacuation stem should remain detached from the socket.
