So whadya Think? Can this be used with a Vacuum Fitting, all Sealed up, maybe some Spatula Silicon around the Edges and a Pump..Bingo..Disposable RCM Wand??
1 LINT BRUSH - eBay (item 270528646311 end time Mar-10-10 18:18:46 PST)
similar thoughts...
Jeff (and sled108)
I use a "Shark" vacuum. A POS as a vacuum, but enough for records (it doesn't create too much vacuum). Even works dry and can handle small amounts of liquid without any problems.
The VPI brush is nice, and if ya want to something more deLuxe, the way to go. You could use a DD turntable if you like. I guess you could use a JK flipflop to half the speed, as it seems that most RCMs spin around 17 RPM (at least as far as I can figure out).
Jeff (and sled108)
