Some of the inspiration:
Rod Elliot, active PA speaker: Project 137-1
Maxim active docking station: Reference Design for a Class D, 2.1-Channel, Audio Amplifier for an MP3 Docking Station - Reference Schematic - Maxim
A note I found that explains a little about the comb-filter effect and dips around the crossover when moving the mic up and down: Mini Convertible: Crossover
similar on off-axis dips: http://www.beatstamm.com/OffAxisResponse.htm
Having found a few references to off-axis dips in FR (see prev. post) I'm not that worried about this aspect anymore.
I changed the LP a little tonight (oh, the joy of changing an active breadboard-filter compared to a huge passive monster). Moved the crossover a little higher as seen here:
Maybe I just placed the mic in a sweet spot, but it looks good:
The curve that dips, is the woofer with reversed phase.
Im pretty convinced that the woofer-ripple is an measurement artifact
The large dip at 300Hz looks like floor bounce to me.
All in all starting to look pretty good considering the (less than) minimal outlay.
I still suspect that you might need a bigger PSU to go loud.
But that is just a suspicion as my electronic knowledge is nearly non-existent.
Actually the PSU is (just) big enough to go (semi-loud). I've tested it close to clipping and it was OK. But your right, more current-capacity would be better.
The measurement setup is very far from ideal right now. To many surfaces close to mic and speaker.
Implemented a notch-filter around 16-17K to remove the horn-peak. Not sure if its audible, but the dogs and bats will probably approve.
Heres a measurment at midpoint between horn and woofer. Approx 0,15,30 and 45 off axis.
Wondering if the "dip" around 500Hz is the baffel-step? Might have to read up on that a little.
According to Rod Elliot the bafflestep-freq is 115/"baffle width". My cabinet is approx 20cm wide and thus 115/0.20 = 575Hz. That looks about right.
Baffle Step Compensation
Hmm. Looks easy enough to implement.
A sketch of a possible filter-design. Some of the blocks can be re-arranged. - any thoughts? I have zero experience with analogue "signal-chains" of this lenght.
Problems related active filters are the same as for the passive. Filter except frequency of crossing should have the ability to change the Q factor of the filter.
If it does, then the active filter down to ordinary calculator.
The correct order should be set using the simulator target response, enter the recorded responses of individual speakers and then changing the order of frequency, and Q,,
factors indicate the speaker recorded in the target respons
Quite by chance may be that LR24 dB acoustic suits B 12 electrically
ili12dB with a Q factor of 1.14 or 12dB with Q 0.85.
PS it is wrong to alter only the frequency, should be changed as needed and Q factor
The problem of acoustic phase and the simulator is that simulators care and counted acoustic phase and those that use simulators to every time and do not work 🙂
There is a possibility that the simulator Account acoustic phase which is not entered on and then do what you want 🙂
ARTA has the ability to measure with enough precision acoustic stage, but if the simulator or the one that works with the simulator does not see, and then the end result being usually wrong.
Theoretically electronic filter calculations perfect cut and it is well with electric hand ...... but enters the game and acoustic responses with their acoustic phase and then ARTA record that record ...... not recorded ARTA wrong, wrong is filter ...... and so in 99% of cases, filter 🙂
BSC included in the first buffer in the signal-chain.
Variable depth and frequency. Not my design. Can be found many places on the web.
Send me PIR file of ARTA. Individual speakers recorded without moving Mic + LIMP file, recordings without the filter
First draft of a filter section. PCB is etched and drilled. Waiting for some free hours to populate the PCB.
General idea: the board is to placed on a "main-board the holds PSU and other misc stuff. Power-gnd and signal-gnd are isolated and joined somewhere near the PSU
Film-caps (ebay-kit. unknown qaulity) are mounted through hole. Resistors (leaded and SMD) are mounted on bottom side SMD-style. A lot easier to replace and tweak.
50X50mm includes this:
Well, A few mistakes I found so far: BSC implemented wrong ( old sketch in final design), I forgot the 14KHz highpass that should compensate for the horn response and level-adjustment for both HP and LP would probably be a good idea.
First prototype of the filterboard and the mother-board it plugs into.
Surprisingly most of it works although i forgot to consider the fact that the amplifier has input referenced to Vss and the other filterparts are referenced to Gnd.
Problems noted so far:
1)The EBAY amplifier has way to much hiss to be connected directly to the horn with the very high sensitivity around 2-5Khz. Solution: replace the active 14Khz highpass with a passive type (which will probably require a single Cap + impedance correction for the horn. - so much for going active...)
2)The EBAY voltage booster turned out to be unstable and this resulted in massive noise on the amplifier output. Luckily someone already found the cure to make the regulator stable: 10/30/50/100W LED application driver (UC3843A). #360customs
![IMGDEAD]](/community/proxy.php?image=http%3A%2F%2F%5BIMGDEAD%5Dhttp%3A%2F%2Fi62.tinypic.com%2Fi4nuow.jpg%5B%2FIMGDEAD%5D&hash=0c3b6babd065d46d772b4f0b6e4c7ba8)
First draft for a limiter. Inspired by ESP: Project 137-1
Limiter and filter on mainboard.
First draft for the sub-sat-filter:
First PCB:
First PCB:
OK, talking a bit to my self, but nothing new in that 🙂.
First sketch of the different PCB´s and parts. Shoehorning it into the box. Hoping heat will not be a big problem.
I can't see how active makes this speaker cheaper or better.
Polishing a turd comes to mind, good active over a passive
is never cheap, cheap is just pointless overcomplication.
The effort is best expended on something far better.
rgds, sreten.
rgds, sreten.
I was wondering when sreten would turn up with his obligatory yet pointless downer.
Unfortunately I can't help or even comment on the electronics side of things.
Sorry Troels.
Sorry Troels.
- El-cheapo active LOUDspeaker
