El 84 oscillator puzzle
Which of these caps would have to be changed to get the required voltage, at the moment its oscillating at 50khz , but the voltage on the play is only 90v and on the erase only around 4v
Any help is appreciated
Regards colin
if the erase head is O.K. I would check:
- the shielded cable to erase head for open or short or solder joint
- the tank circuit for broken wire or solder joint problem with secondary coil or with cap .022
- or this cap itself
- cable shield usually is a mesh made from thin wire, inspect with a magnifying glass for tiny whiskers or single strands on both ends of cable which could cause a partial short ...
happened to me more than once ...
I have now changed the shielded cables , still no luck, do you think the 220 and 150 caps are UF or PF? I've probably put the wrong ones in , I've also disconnected the screen wire from resistor 68k and that's made no difference as well as changing the valve,, I did notice however that as the voltage surged on initial switch on the ptp went right up then back down again
The valve isn't the problem, as it oscillates at the correct frequency.
120 and 150 are pF, pico-F, they form an AC voltage divider for the 100v pre-magnetising bias for the recording head.
Caps with a dot .xxx value are uF, micro-F, so you have
.0022uF=2.2nF, nano-F.
.022uF=22nF
.0047uF=4.7nF
It sounds strange but I think the oscillator is pulling current away from the first ecc83 valve as the guitar sounds really awful ( just through the machine without the echo ) like the valve isn't getting enough juice, tomorrow I'm going to take the el84 out to see if the sound improves
