Eiaj input for AD1865
Hello,
I'm using with satisfation a TDA1545 dac on Nec CD6x directely connected by EIAJ output.
Now I'd like to try AD1865 and I'm looking for the way to connect it directely to EIAJ .
Anybody have tried ? or can help me?
Guglielmo
Italy
guglielmope said:
Hello,
Guglielmo
Italy
I assume you are talking about the spdif output on the CD6.. (Is this a player or a NEC multi-spin cdrom?) Or is this I2C?
Spdif will require the use of a receiver IC compatible with the AD1865 data format..
You'll need to provide a lot more information..
FWIW have you checked out the Twisted Pear Audio dac modules?
Hello
the player is CD6, but I'm not using SPDIF out.
I'm using the eiaj output from the ic CXD2510G.
This output is perfect for TDA1545 or TDA1543A (not normal TDA1543 that use I2S)that use the same EIAJ protocol but not for AD1865.
Now I'm looking for someone that have realized a conversion circuit that can solve this problem.
Ciao
Guglielmo
