efficient and simple 2 way
So I have the CSS ERT26 tweeter and the Tang Band W6-789E 6.5 woofer, both are efficient. I am looking for thoughts on a simple crossover design? Any help would be great!
Please see attached pics for specs.
Ex-Moderator R.I.P.
Joined 2005
Do you have thoughts on the values of the components shown in the last post?
hmmm, not so easy without measurements, or listening
for one theres drivers own frequency response
drivers varying impedance result in different component function
tweeter low resonance peak plays a role too
and theres the "BSC"
it means that you have a loss in midbass
its where a voice gets its volume, and thus very important
but usually the midrange series inductor needs to be bigger than the calculated
you could try something like 0.5-0.8mH
paralel cap and resistor could be anything
maybe try 5.2-12uf
resistor, maybe 5.7-10ohm
all those will influence each other
tweeter series cap could be like 4.7-6.8uf
paralel inductor could be a tricky one
maybe from 0.2mH-0.4mH
resistor may not be needed, but try smal valaues from 2.2-5.7ohm
attenuation resistors
you might get away with just a series resistor
but a changed impedance will have influence on xo function
but you need to build a test xo where you can easily change components
do your layout exactly like in the shown schematic
start with cheap components
and please, dont short anything, it could burn your amp
well, you could try and start with just a series inductor on midrange, and a small series cap on tweeter, with a series resistor
maybe you will like it, for a while
Thanks Tinitus, this will give me a great start!
Inductor: What do you mean this "tweeter looks so bad" do you think I made a bad choice on selection? I chose it because of the price range the
Vifa D19TD-05 3/4" Poly Dome Tweeter and Dayton DC28F-8 1-1/8" Silk Dome Tweeter are both in my price range and easily available, so would one of them be a better choice?
RG
RG
Dear RG,
Although you get some friendly answers on your request, unfortunately none of them hit the nail on the head. Trial and error is not going to produce a good x/o. Speaker x/o is a little more complex than assumed here.
You must measure the chosen drivers in the box you are going to use. Manufacturers sheets are not usuable, in that the speakers usually are not measured in a box, but on an IEC baffle, yielding rather different and much smoother SPL curves. The so called Baffle Step is not present in IEC baffle measurements; neither are all sorts of diffraction effects, that must be taken into consideration, when designing a x/o. Furthermore, TB is notoriously known for its highly optimistic graphs.
My advice: download a free lsp measurement program, such as ARTA or Holmimpulse and import your measured curves (so called .FRD and .ZMA file) into either Boxsim or Speaker Workshop.The learning process will be hard in the beginning, but once you' ve mastered this, you will be able to design almost any system and x/o you like.
Good luck,
Eelco de Bode
Dear RG,
With the Dayton, 2.2 kHz (or even 2kHz) will be fine, provided you apply acoustic 4th order LR. Often a relatively simple electric 2th order x/o will, combined with the drivers own roll off, produce a nice acoustic LR 4 with just a few components. But then again, optimum results can only be obtained by measurement and proper simulations in an x/o program.
Kind Regards,
Eelco
