efficient 15" subs that will drop in an automotice IB setup, 10CuFt/sub sealed(ish)
looking for a suitable pair of subs for an Infinite baffle set-up in a car. I've posted in here because it is a set up more like a home theatre setup than you usual in car boomer.
My criteria are:
efficient, 97dB/w minimum the more the better.
They will be using the boot/trunk for am emclosure, so about 20CuFt for the two subs and it won't be the most rigid/well sealed enclosure ever created
I'd like 2 X 8ohm subs (wired in parallel) as the amp produces 2000W @ 4ohm
Low Fs, this will become obvious when you read the first point of my thoughts below, the lower the Fs the lower I expect it to drop, I want these to go as low as possible.
My thoughts are:
A pair of decent proaudio subs wired in parallel with A-periodic membranes to limit excursion at lower frequencies, I have seen this work to good effect. This would then be on a sealed baffle behind the rear seats, with the rear seat modified to allow the sound through.
So far the best option I've found with my limited knowledge is this:
Precision Devices PD1550
http://www.precision-devices.com/showdetails.asp?id=14
I dont know if 18s would fit but this looks ok:
Precision Devices PD186
http://www.precision-devices.com/showdetails.asp?id=3
I've had B&C reccomended but couldn't find anything better, what do people reccommend for this?
My criteria are:
My thoughts are:
You also might consider this as it's a pretty rugged unit with that quartz composite cone. I have a pair that I use in my Altec A7 cabinets.
http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=264-425&DID=7
