Edit button
Hi i would like to know if it is possible to leave the edit button on our posts it would be nice to be able to go back and do some cleaning because whe often see Photobucket without the image if the edit button was there like most sites whe could go fix the problems and the site would stay cleaner. thank you André MrAcoustat Sévigny
The edit feature is active for 30 minutes after you post. Beyond that, please use the report post button and request the change through a moderator.
Thank you.
Thank You sir i have decided not to use Photobucket anymore i will like others have suggested use attach files.
