Yes I have 12 volts on the power supply fets .
On the small transformer near the 494 I also only get 0.64 volts on the windings .
What information do you need and I will provide it
Did you follow the circuit back from the transformer to see if you could find a break in the circuit or a defective component?
Pin 8 goes back to 3 transistors .
KTC3206 amd KTA1273
Do you happen to know of any good replacements for these ?
KTC3206 amd KTA1273
Both 3206’s test fine but I swapped locations and now I have no 0.00 volts on pin 8,11,12 so 1 of them is defective and also the A1273 measures shorted .
They have all over heated at some point
I’m gonna have to follow the circuit back even more since I replaced the transistors and diode amp still shows no life still get 0.64 volts on pins 8,11,12 of the 494
- General Interest
- Car Audio
- Eclipse ZA1200
