eclipse xa5000
Using a multimeter to determine if the gate voltage is as it should be will not provide definitive results. Many amps will read less than 1v when working perfectly and producing the target rail voltage, especially when the supply is regulated.
Do you have rail voltage on the output transistors for the other channels?
Yes there is voltage. On the sub channel, ( power supply FETs are in 2 pairs of 2) one of the gate resistors is bad and the signal isnt getting to the transistor. This most likely caused the other transistor to fail??
The rear channels are working but the fronts are not.
