Eclipse PA5422 now won't power up
Received this amp which was powering up without REM connected. I found a diode 4148 and NPN marked 24 and PNP marked HR transistors in down the REM path all failed. Replacements chosen using BC846BT/BC856BT. now the amp won't power up and the I cannot get +12vDC to pin 12/13 of the TL494.
All resistors around the area seem to be OK.
Is there a schematic available?
Is the diode open? I think it's being used for under-voltage protection and 13v seems too high.
Is the transistor shorted/leaky.
I think the NPN transistor was supposed to be a digital transistor with internal resistors. Using a transistor without those resistors and no series resistance on the board may be your problem.
Try to get the numbers from the diode before removing it in case it breaks up when desoldering it.
Yes the diode has a marking of A2 on it. A 1N4148 AFAIK
Theres 13vDC on the cathode of D801 fed from the REM terminal. Originally, D801 A2 diode was dead shorted when I started working on this amp.
Curious on if I can use a high ohm rated resistor instead of this diode. REM voltage is not getting to the NPN. Or maybe the diode is backwards? Im not sure.
Not great but attached.
Is the original diode open? It's likely something like an 7.5v zener.
Was the NPN transistor shorted or open base to emitter?
Do you have any 'digital' transistors? If not, you could get by by inserting a 1k resistor in series with the gate leg of the standard NPN transistor.
The attached file is very roughly what I think you have. R244 is allowing them to use a standard NPN transistor instead of a digital type transistor.
In series in the remote, diode, NPN base. You need something to allow a voltage drop in that circuit. I can't tell if there is a pulldown resistor on that circuit but if you, you can (for testing) insert the resistor at the remote terminal.
I'd use a 7.5v Zener in the place of the diode.
If you're uncertain about the condition of the NPN transistor, replace it.
