Eclipse 36401
Yea, I need a better one for sure.
yea, it was connected to the emitter or third leg of the output fets while I was running an audio signal into the amp. When i pout the probe on the speaker outputs I seen the same signal, same wavelength and voltage. Thats why Im confused as to why there's no actual audio when hooking up a speaker. I guess I can try again and see if the same signal shows on the speaker itself, again maybe im reading something wrong but i have the probe set to AC at X10
