ECC88 - 6DJ8 Cascode Plate Curves
You can estimate from published curves.
Zeroth approximation:
Low triode works into a short circuit (vertical load line). Anode current merely goes through the upper triode - infinite Ra so curves are actually horizontal lines.
First approximation:
Low triode works into a load of 1/gm, so almost vertical load line. Upper triode sees lower triode as cathode degeneration resistor of Ra, so upper anode impedance is (mu+2)Ra. Curves are pentode-like.
Second approximation:
Remember that gm depends on current. This is when it gets messy.
ECC88 cascode curves with 50V on the upper grid.
