ECC81/300B Push Pull Amp
I built this 2-stage 300B Push Pull amp.
It was pedestrian with garden variety 12AT7/ECC81,
but really sings with super ECC81 tubes like
GEC A2900 and ECC801S.
After several failures building PP amps, this is a keeper.😗
Inspiration came from John Tucker's parafeed 45, which uses
CCS loaded parallel 5965 (12AT7 variant) triodes as driver.
I am in the process of building a 5691 (super 6SL7 ??) drives 300B/45 PP version,
6SL7 has more mu.
Not sure if 5691 has as much super power as A2900 or ECC801S ?
Currently, it is using the secondary of LL1660S (an interstage transformer)
as the phase inverter (center-tapped choke).
It is lacking some lower ends due to the inductance (~20H).
Suggestions on the availability of higher inductance ( > 40H)
center-tapped chokes (or 1:1 inverted transformers),
and comments are welcomed.
I had tried the LL1660S primary as a splitter. It didn't sound right.
I think the primary is gapped for a certain account of bias current.
I had also considered using 12AT7/12AU7 as a LTP, as you said, but it does not have enough gain
in my system. I don't have a preamp.
