ebay amp L20 power amplifier
more ways to rome....
The sport is of coarse with little or no money to produce the best hifi (sounding) or high-end power amp.
I like that too!
With what you have " on the shelf" is ALWAYS an option. There is no good or bad ,,,,,it's what you decide/like.
I could open the power supply and see if the transformer has a - and + tap that they only use 1 of and if they do I may just use 1 transformer for the whole amp. the power supply is capable of 1300 watts, something like 27 amp at 42vdc. I am powering a measly 700. Well I'll open up and see.
Thanks.
Srinath.
You used 24 volt trafo, that would be just about 42vdc after you rectify it.
I am doing 42vdc power supply, I may open it and check the trafo. I may have a 24 too, though mine isn't a toroid cos I dont have that center bolt that I can see.
Thanks much marcoben.
Cool.
Srinath.
Check list:
1) Check voltages in power supply and continuity to boards
2) Check continuity from input jacks to board (Screw down terminal boxes can look connected but are not!)
3) Check for continuity from output to speaker terminals
4) Check for continuity in grounds
If you smelled smoke when you plugged it in, you may have had a short in output and a resistor burned up. Look for a blackened resistor on board
L20 V9
I have built this amp as two monoblocks and posted elsewhere on diy audio. I had nothing but trouble initially but after buying 2 more boards have finally got the amps working and 99% finished in their cases. They sound outstandingly good and in some ways I prefer them to my 300B reference monoblock amps (60W/ch.). I built them with speaker protection modules as I still don't trust them fully. However I have about 20 hours on them without problems. My problem is I have 73V rails due to my mains voltage being high and wrong selection of toroids. David. 🙂
L20 V9
Yes, +/- 73VDC. Actually the rails were +/- 74V last time I measured them. The trouble is I used toroids which would give +/-70VDC with 240VAC input but my mains voltage is usually 251. I had all sorts of problems with my first set of boards but I don't put the problems down to the high DC although it certainly made a mess when the output semiconductors failed several times. I think it was more my layout and fiddling about that caused the initial problems. Anyway, the amps are working now and sound very good, excellent actually. To save the cost of new todoids I may make up some sort of voltage regulator if I can figure out how to. BTW, my power supply electros are only rated to 80VDC so that's another reason to drop the DC volts. Regards, David.
L20
You are on the edge of blowing up. It shows how easy an L20 amp can handle various DC voltages.
specs:
Input Voltage Range: DC±10V - ±70V
I use 24 volt AC ,VDC 33 , 400watt toroidals. 24 ampere per channel.
sound is fantastic.
best regards,
Marco
I have a +/-57 vdc and 500va chassis I am planning to put it into.
I am not sure what its ampere capacity is - I want to guess its around 6-7 amp. The fuse in that chassis was 6.3 amp.
What would this amp deliver in terms of watts into 8 and 4 ohm loads.
Cool.
Srinath.
