While doing nonos mod (done that before, successfully), becouse I can't count more then 10 pins rightly, I conected pin 23 from SAA7220 to pin 12 insted of pin 11 of SAA7210
to restore mute funcion. All I got after "mod" is error message at dispay, really hot SAA7210/7220 and TDA1541A, dics doesn't spin, lader is working though
, voltages for Philips chipset seems to be OK.
Any hint how to fix it, thank you?
