Hi all,
I have a pretty cheap pair of speakers, the rest of my hifi is a little wasted going into them
Cambridge Azur 540c cd player, Aikido pre, fostex lab 600 amp...
They are the Wharfedale Valdus 500's. I brought them in high school because they were 'VERY' cheap, and i'd heard my mates ones and they were loud and bassy.
Anyway is there anything i could do to improve them a bit, i know nothing about speakers really but i read that padding the insides helps with bass control? Can i improve the crossover?
Or shall i just leave these speakers alone and use the vintage Wharfedale Dovedale 3's that are lying around (and sound nicer).
Craig
Craig
My opinion of that range of speakers is that they are also cheap and bassy. I would obtain some BAF wadding from your local Maplin or fabric shop and cut a piece the length of the vent and wide enough for you to roll it up just tight enough to slide it gently into the vent.
richie00boy, do you mean the air vents at the top and bottom of the speaker?
The upper vent is for the mid driver + tweeter and the lower vent is for the 2 bass drivers.
Will padding both help, or just the bass vent?
Craig
Craig
The bass one is the main one to do but do both if you can. The mid one does actually have some bass output I believe.
Would putting some series resistance in with the tweeter be a good idea, i have just been listening to the speakers and the treble really does make your ears hurt sometimes.
A proper attenuator would be needed as simple series resistance would alter the crossover frequency. It might turn out OK though.
But it could be a cheap harsh tweeter or the level that is the problem. If the former, changing the level might not help much.
Well then im guessing its probably a harsh tweeter, i have read that they are cheap ones.
Its a shame really because the rest of the speakers sound OK. Not hifi nor detailed but the bass is actually very punchy and deep, with a bit of EQ'ing the sound can be very balanced apart from this nasty treble.
My friend who initially had these speakers moved on to a pair of B&W's which instantly sounded far superior when i heard them a few months ago.
Craig
Craig
LOL, the Valdus are the speakers that caused me to get up and leave Richer Sounds with a vow never to return again. I went in after some Mordaunt-Short Pearls and the salesman said they had sold out and I should buy the Wharfedales as they were much better anyway. I was disgusted that they could be so wrong with their recommendation.
Richer sounds salesmen often dont know a lot, they are pretty arrogant about their knowledge too i found.
Anyway!... are you dissing my speakers 😉
Craig
Craig
richie00boy said:A proper attenuator would be needed as simple series resistance would alter the crossover frequency. It might turn out OK though.
How much does it alter the crossover frequency?
Example:
The tweeter crossover point is supposed to be 2,000hz. The tweeter is 8ohm. I add a 10ohm/10 watt resistor in series to the + side of the tweeter.
How does it shift the x-over point? Up or down?
The frequency will go down, it depends on the order of the filter as to exactly what happens.
The -3dB frequency of a 1st-order filter can be found by
F = 1 / (2 * pi * R * C)
where F is in Hertz, R is in Ohms and C is in Farads
- Easy speaker tweaks..?
