I lost drive, one of the diodes on the 4080 failed. I used a 1n4148 and drive is back, not sure if that is the correct diode but worked for now. Which terminals you want voltages for?
With the rail caps discharged, pull the 4080 and lift pin 5 and reinstall the IC. Do you now have a square wave on 5, a triangle waveform on 6 and DC on 7 that's centered on the triangle waveform on pin 6?
