Earthquake PH D2
sorry for getting back so late. i try at first with my my Leader audio generator and just to be sure i connected a kenwood cd player to it, and the humming noise won't stop, i dont do repair on a daily schedule it a when i get around thing for me. my power supplys are amrel pps 1326 adjustable 13v 0-5 amp and astron 12v-20a i use on my work bench. here is what i don't understand why i'm getting 80volts on Q7 Q8 Q7A Q4 Q6 Q2A and other 6 output i'm only 36.05 volt from gate voltage,
No i dont think it is the head unit, even when i install it in the customer car with new RCA new head unit it hums, i remove the RCA socket from the board to check if one of the pin was broken everything was find there, could you tell me what the resistance i'm looking for with respect to power ground, and i measure the signal across the shield it,s around 60.05Hz, resistance across the RCA drop a little once i move the rca socket and resoldered it back.
. Resistance between RCA shields and power ground is 111.6k ohm, sense spoken with you last, i try the amplifier out again and it didn't make the hummed sound anymore, thanks for the help well appreciate, but now it appeared like the amp is clipping when i turn the volume dial up, would it be fair to say base on the schematic i uploaded that IC1 NJM3403ad is not functioning,
Sorry for the confusion all i was trying to say at one point i had try the amplifier in my car and it gave me a humming sound too. but now i'm at my work bench and this is what happening now, Resistance between RCA shields and power ground is 111.6k ohm, sense spoken with you last, i try the amplifier out again and it didn't make the hummed sound anymore, thanks for the help well appreciate, but now it appeared like the amp is clipping when i turn the volume dial up, would it be fair to say base on the schematic i uploaded that IC1 NJM3403ad is not functioning, Test unit i am using now is a Astron 12Volt 0-20 amp power supply Leader signal audio generator, fluke 83 multimeter and HP 100mhz ocilloscope.
