Hi all!
I am finally putting my first amp into its case and I want to make sure I connect the earth pin of the wall socket correctly. From what I have read, I think I should connect it to a point on my chassis with a screw and to GND on my PSU. My PSU has dual secondaries and two bridge rectifiers. Is this the correct scheme? I want to be safe.
Thanks!
Thanks!
fig 3.18 has omitted the diodes shown in fig 3.17. Do not omit these high current diodes, if using the Disconnecting Network.
Better still use the link for our own guide
http://www.diyaudio.com/forums/diya...udio-component-grounding-interconnection.html
