Early clipping with JX Amp
I finished my second mono today. 100ohms current limiter resistors.
Fired up, same problem. So most probably no wiring or part error.
Than I removed the current limiting resistors (R13, R14) completely.
Slightly better
55 Watts into 8 ohms at 1kHz with 1% THD whereas 49W before.
35 Watts into 4 ohms at 1kHz with 1% THD whereas 25W before.
It's not the current limiter.
Is it the concept itself?
Ok,
I ask in a different way:
Is it possible that the 2SJ109(BL) isn't able to drive the amp for higher current? BTW: I tried 2SJ74BL/2SK170BL too with similar result.
If so, we can't use the J-X for higher power, right?
So we can double the power into 4/8 ohms (compared to Aleph J) by building the X Version of Aleph J but that's it.
Can someone with a working amp confirm this?
Sound
I should not only post problems but also the good things 🙂
These amps sound marvelous and as long as one don't start a party or drive low impedance speakers there is no problem with 50W/8ohm; 35W/4ohm.
The amps are not played in at all but the first impression was that the J-X sounds a bit fresher and "lighter" than the XA version. I can' tell about smoothness as I think the amps need to run for a few hours first.
the pdf enclosed describes the scientific way 😱 to do it right under "AC gain adjustment"
easier you hear what you want or need for R24😀
mind that R24 is called in this plan R115 😱
another source are the first three Zen articles at First Watt🙂
(pdf by curtesy of Zen Mod)🙂
