Hi!
There are a lot of components that we use and they are not in normal Eagle Libs, like MJE and MJL's, PGA2310, some AD's and OPA's, etc.
Is there a way to get them, or I must draw all of them??
In Cadsoft site they have a lot of libs but none have what I want.
it is quite easy to make your own, just copy the component footprint out of one of the other libaries and paste it in your own
draw a symbol for it, and name all the pins on it
put the device together by connecting the pins to the right ones and your done
the only annoying thing is when you dont have the component footprint and you have to make your own, but most things come in dip, soic, ssop, to220, etc. that you dont have to muck around with making your own there
ohh and if your device comes in a standard pinout, like most opamps then just find a different device with the same pinout as the one you want (and rename it if you need to)
hello everybody !
I need help
I need library STK4050 for eagle software
I have stuck to searching this library in Mr. google
I hope all master in this forum will help me to find this library
thank's Master
I need help
thank's Master
