Does anyone here by chance have any Lateral FET models for Eagle?
Does not matter if it is 2SK1058/SJ162, any of the TO-247/TO-264 Exicon Lateral FET's or any of the Semelab Lateral FET's in TO-247/TO-264.
Thought I could use my IRFP240/IRFP9240 models but the pinout doesnt match with any of the Lateral FET's. They all are GSD, while the IRFP240/IRFP9240 are GDS.
Well, I bit the bullet and did my own models, a little copy/paste, a lot of headscratching and 2 hours later, my first 2 models.
Here is the datasheet : http://www.profusionplc.com/images/data sheets/ecf20n20.pdf
Models are attached, they should be OK. 🙂 Just remove the .txt extension.
Exicon ECF20N20/ECF20P20, TO-3, 16A, 200V, 250W.
I did made the laterals from a other shape in eagle, but one thing I do not get why i get for the part U$1 and then G$1 special the $ do not belong there see the picture, somebody now how to make dat properly.
Well upload of foto do not work, failed.
it is normally T1 T2 etc, I have T$1 etc, the dollar has to get rid and I do not now how.
thanks.
thanks.
D and S swapped at 2SK1058 -> http://www.diyaudio.com/forums/pass-labs/183482-25w-cl-amp-lateral-mosfets-10.html#post4198846
Here's fixed: View attachment lateral power fets.zip
Here's fixed: View attachment 461620
Thanks, I did already solved but have download it to see.
regards
- Design & Build
- Software Tools
- Eagle Lateral FET models.
