Good Afternoon, All.
I have been racking my brain for the past fortnight trying to work this out. My current task is to "computerise" my CD collection (so that I can remove my CD/DVD/VCR cabinet from my lounge room and so that I can find the CD's I want to play.)
My fundamental requirements are:
Also, there are few of us old fogies writing on these sites who insist on listening to albums from beginning to end or those albums which have contiguous track . (My local shop couldn't even work out what I was talking about. I had to pretend I was listening to live concerts from Lady Gaga before they understood whatt I meant. If I ever let the "Beethoven bomb" slip into my conversations, their faces glazed over.)
I like the idea of EAC (v1.0 Beta 3 from August 2011) and have ripped about three CD's but am confused with the CUE files. I have followed the blowfish recommendations for creating my FLACs:
Is there a solution to this?
Are there any players actually work to play EAC's non-compliant CUE files?
I can get Sgt Pepper and Wish You Were Here to play back correctly if I rip as a complete image. The CUE file created in this case plays correctly in Foobar2000.
I have written to this, my favourite audio forum, because of the accumulated and considered wisdom which appears lacking elsewhere on the WWW.
Anyway, if anyone can help me out, I would appreciate this.
George.
P.S. You can see a small portion of my CD cabinet at the right of the pic on my webpage. GB
- playback with the gaps the same as the originals,
- bit-perfect reproduction of the sound files;
- to be able to burn a copy of my .wav or .flac back to a CD ... well, why not?
- Append gaps to previous track
- Cue sheet - Multiple WAV files with gaps - noncompliant
- What is everyone else doing to keep the gaps in their playback of their CD's correct?
- Are there other problems or practical difficulties in the long term if I burn my .flacs as images of the whole disk rather than track by track?
George.
I am in the same situation as you are and also looking for feedback from those who are more familiar about cue sheet, etc.
There are a no. of exceptions in my case.
Firstly, I don't trust storing my files in the Hard drive, I will be storing them on BLU Ray discs(*). Also I wouldn't be converting all my existing CD discs
Secondly the size of Wav and Flac is not that much different I would rather store them(audio tracks)in WAV format and in future if there is a more efficient way to store them I will then convert all my WAV files. Henceforth I will convert as many of my audio disc tracks and store them in WAV format, which is as an advantage of being bit perfect. I don't think Flac is bit perfect.
* You can store about (40-45 CDs) in WAV format in 1*25G Bluray Disc assuming 555-600Mb in one CD.
flac is a lossless format that simply works, no need to worry.I don't think Flac is bit perfect.
Bluray discs as with all discs are also not always guaranteed to last, store on a hard drive and have backups.
Still got to to read the data of the bluray disc
Main question still unanswered 😉
Thanks for that chaps,
But my main question is:
Which media players will plan non-compliant CUE files from Exact Audio Copy? For example, Foobar doesn't and Winamp is supposed to but I can't get it to work.
I need to keep the gaps in my music as they are on the CD.
Regards again,
George.
Regards again,
George.
What I've been doing for 10 years and I listen to 'whole' albums:
Using Exact Audio Copy,
Pink Floyd's album "Wish You Were" plays back properly.
No need for a CUE file. 😉
- Append gaps to previous track (default).
- Rip and compress to separate files using lame, flac, qaac etc.
- Properly tagged files.
- \Musik\%albumartist%\%album%\%tracknumber2%. %artist% - %title%
- Play back in foobar2000.
cogsncogs, do you mean decoders that support gapless playback?
From my own experience, I think the "standard" CD track gap is 2 seconds. I'm not sure where I learned that; it's been a while.
I know Winamp use to have a gapless playback plug-in available, but I understand that functionality is built into the player now.
What I have done to my tracks is make them with little to no gap in the stored file itself. If the track does need that bit of silence, I can use an editor to save it to the beginning or end.
I have also created a two-second silent track. This track can then be inserted into my playlist between songs, if I want that CD/LP -style of playback.
The so called standard 2 sec gap can vary wildly in commercial music. Its length is determined by the (re)mastering engineer. I never remove it as it would destroy my album listening experience. The only time I would ever edit the silence between tracks would be if I were making a 'mix' CD and the gaps were too short/long. It's an art form! I can think of quit a few instances where the re-mastering engineer screwed it up, which I corrected, of course. The 2 second standard is a standard of some burning programs.
Almost all modern encoders/decoders can write/read the gapless info in the header. Now players that can properly handle that is a different story.
If the silence is part of the audio file itself, then gapless playback would seem impossible.
From my description above, it's easy to determine that I certainly haven't destroyed the album experience.
If the silence is a part of the experience, it's not a problem to configure the ripped playback to match it, virtually exactly. If it's not a part, I don't need it.
Songs like hidden tracks at the end of a disc, with say 4 minutes of silence added on... that unnecessary stuff just gets jetted (discarded).
I know nothing about gapless info in the header.
I did a little reading on it after my post. Not a whole lot; I'm still assuming the user has to input the amount of silence into the header (perhaps tediously), or software must be capable of determining the silence for auto-input (which I might not fully trust).
But I never had a requirement of "playback with the gaps the same as the originals." As I said before, there's situations where it is important, and situations where it isn't. The latter undoubtedly outnumber the former, at least for me.
Here's a good example to try at home:
From the Crosby, Stills, and Nash album CSN, take the tracks "See The Changes" and "Fair Game." Play them in that order, with a small gap between them. It should be about 1 second from the "farther away" of the first song to the guitar intro of the second (but it's really only a tiny bit more than 0.125 second between the actual audio. You can view it by zooming in with your editor).
More is too much, less isn't enough.
Rippers like EAC get the exact lenghts of the gaps into the ripped files while ripping the way the CD layout specifies itself. No need to violate the audio files with gaps you guess.
It's an art form It is and this is a topic near and dear to my heart. I have an audiographic memory of some albums and cd's. Mostly albums I heard before I was 35. The remastering engineer, producer, engineer, artist, would often put the music together with the gaps intentionally of a given length. Brian Eno's production of Talking Heads 'More Songs About Buildings and Food' is one that pops to mind. He mastered and spliced it together so that the tempos continued through the silence between songs Track 1 Ends😀own-up-Down silence silence Track 2 Begins: Up-down-up down Continuing the next song on the beat, and in time! This means that the songs need to be spaced precisely apart in ms to have the same effect, and mp3 rips destroy this continuity of albums. Those spaces were put there for a reason, in the length specified.The so called standard 2 sec gap can vary wildly in commercial music. Its length is determined by the (re)mastering engineer. I never remove it as it would destroy my album listening experience. The only time I would ever edit the silence between tracks would be if I were making a 'mix' CD and the gaps were too short/long. It's an art form
Thanks to all.
I probably worried too much about this. By ripping the tracks according to the blowfish guidelines, which are very similar to cogsncogs recipe, and playing with foobar or Windows Media Player or VLC media player, they all run on perfectly, maintaining my sense of "audiographic satisfaction" as the players work through the "folders". My Mitsubishi Pajero audio player puts in a gap of about two seconds while it "thinks" about what to do next, but the basics of the rip and storing the songs all works fine for my home system.
There are no gaps in live concerts - and no audio artefacts between tracks - and the gaps between tracks on my old Beatles CDs are the same length as they were on the LPs. (Although I hate the way on the new Beatles stereo version re-masters that they cut the final notes shorter than the original - e.g. on Hard Days Night - so that the modern listener is not offended by tape hiss. Young people today ...)
Clearly the .cue sheet is much more important for burning CDs rather than listening to the files from your HD or USB stick.
George
George
- PC Based
- EAC non-compliant CUE sheets: which players work?
