E88CC / 6922 Datasheet Limiting Values
In the Mullard E88CC datasheet, there are a number of different limiting values specified for Anode voltage:
Anode voltage, Va0 max 550V
Anode voltage (zero cathode current) Va max 400V
Anode voltage Va max 220V
Anode voltage (max anode dissipation 0.8W) Va max 250V
Can anybody explain to me what the first of these is?
The other three seem fairly self explanatory although I'd be grateful if any of you could confirm that my understanding is correct based on the following. In my design, I have the quiescent anode voltage set at about 220V with a cathode current of 4.5mA, giving an anode dissipation of 990mW. With full input signal level, the anodes swing up to 350V, when the instantaneous cathode current is 3.7mA, and down to 80V, when the instantaneous cathode current is 5.4mA. Am I operating the valve outside its rated limits?
The VaO is the maximum voltage that can be safely placed on the Anode without fear of damage by arcing. Most double triodes of this design operate happily with 400V HT available. Valves are great, over current and the Anode heats up and the current reduces and causes that pleasant compressing/limiting effect. The only real issue with over current is if the Cathode is at the wrong temperature, too cool, that will strip the Cathode.
Plate dissipation in datasheets is average, so you can allow for peaks higher than max as long as the average is not over max limit.
These tubes (6922) are low voltage tubes, good idle state plate voltages around 90-150V. Sounds to me you need to change to 6SN7 or something similar.
When the Anode starts to glow dull red, it is less efficient at absorbing electrons and so the flow slows down and the current is limited.
Under biasing an EL34/6L6 show what happens on a grand scale. The Anodes glow. If you use an 813 in class C and overload it, the Anode glows but as they have carbon Anodes, they continue to draw excessive current and eventually the glass envelopes implodes. I have done it!
Carbon doesn't emit electrons.
Looking at the ECC88 and E88CC datasheets, it looks like you can get huge output swing at very decent current levels.
Im a little surprised these valves arent used more regularly in LTP phase inverters capacitively coupled to power valve grids - is there a reason why other valves are favoured for the PI, such as the ECC81 or ECC83? Im more familiar with guitar amp schematics so maybe in the world of hifi, different valves are preferred.
Sorry for dragging this a little off topic.
