Hi
it`s the first time i participate in diy.com.
I have dynaudio crafft loudspeakers, i trie to open but the units are glued to the box.
does any of you now how to open?
Vitor
Vitor
I contact dynaudio and they confirm that the drivers are glued but don`t tell me how to take the units off.
The replay was(if a driver is not working, go to a autorize dealer) they also don`t tell how to take them off.
The importer of dynaudio in Spain told me that there`s a way, he ask me why i want to take the drivers off, i told him the true and he refuse to tell me, i (should have lie to)
My idea off changing the internal wires is getting very ward!!!
maybe you can remove the backplate and poke on the driver😀
I think the remove the cone&bobin&spider when they remove a defective driver, since its already defective.
The back of the louspeaker is also glued, imagine if it`only a loose wire will they damage everithing...It`s a really
TOP SECRET LOUDSPEAKER
I decided a few months ago to biamp my Dynaudio Special 25's using a DEQX as a crossover. The woofer came out quite OK, but there was no way that tweeter was leaving the cabinet. Like you, it felt like the tweeter face plate was glued in position.
The only way I could remove the tweeter was to take it out backwards. I had to take the inner 3 screws out and grab the tweeter from behind. Because the woofer was already out I just put my hand inside the cabinet and grabbed the tweeter from behind and pulled it out through the woofer hole.
[The only way I could remove the tweeter was to take it out backwards. I had to take the inner 3 screws out and grab the tweeter from behind. Because the woofer was already out I just put my hand inside the cabinet and grabbed the tweeter from behind and pulled it out through the woofer hole.]
My problem is that the woofer is glued, Dynaudio confirm, but don`t tell me how to take it out!!???
Is there a way to push through the reflex port ? Or is this a model without the reflex port on the back ?
Charles
Charles
[Is there a way to push through the reflex port ? Or is this a model without the reflex port on the back ?]
Hi Charles
there are 2 reflex port below the woofer, but small.
Vitor
Hi Charles
Vitor
- dynaudio problems
