Just picked up my second pair of Dynaudio 15W75 4 ohm woofers on ebay so I can clone a Gemini (normally MTM with 2x 8 ohm 15W75s in parallel and 8 ohm D260 tweeter per side). Question is, will it be ok to wire the woofers in series and use whatever crossover design that is already out there for the 8 ohm drivers normally in parallel? Will I need to modify the crossover at all? Or would bi-amping this setup be the way around any problems with the woofers wired in series? --Jeff
