FS: Complete Drivers and original crossover to build the Dynaudio Finale speaker kit. I was saving this kit for build this great speaker, but frankly I won<t have the time, neither the space to use them, so my lost is your luck. This kit is long gone, impossible to obtain, I bought the drivers and the original Dynaudio Crossover over a period of 5 years, way back then.
READ CAREFULLY: Both the woofers and the passive radiators had their original foam surround destroyed, but was able to source the original Dynaudio replacement rubber surrounds. I had both woofers reconed by a professional in Montreal, using these rubber surrounds, so both are back in perfect condition, BUT>>> Both passive radiators still have their damaged foam surround, and need to be reconed. I have the replacement rubber surround, still in their original packaging, and it is quite easy to replace the surround since their is no voice coil to carefully align on passive radiator. SO YOU<LL HAVE TO DO IT yourself, (DIY you remembered 😉
So the kit contains all the drivers, in the original Dynaudio packaging, drivers where never installed, were stored in perfect condition, and boxes where rotated over the years to prevent any damage to the suspension. Drivers are virtually new (except for the passive radiator surrounds...) READ>>> What is missing are the <Variovent> ports, as listed in the kit documentation. I asked Solen in Montreal and they said it is quite easy to build using a simple round plastic ventilation vent, and add a few sheets of loose absorbent material, such as the losse felt inside speakers. It is just a loose restrictive port, such as a normal port stuffed with loose foam. Quite easy to build...
See discussion here: https://www.diyaudio.com/community/threads/closed-box-vs-aperiodic-box-variovent-dynaudio.408624
Kit Contains:
-2X Dynaudio Esotec D-260 tweeters
-2X Dynaudio D52AF Dome mids
-2X Dynaudio MW150 Mid-Woofers
-2X Dynaudio 30W100 XL, 4 ohms woofers
-2X Dynaudio 30W100 SL passive radiators
-2X Dynaudio original rubber surrounds, to repair both passive radiators
-2X Dynaudio Finale Crossovers, assembled
-Kit documentation kit enclosure drawings, etc...
Not included Dynaudio Variovent ports
I have tons on pictures, showing all drivers, I posted here only a few to show you how nice they are.
So you just need to build the enclosure, recon the passive radiators, and you"ll have a pair of great Dynaudio speakers costing easily 5k$ and more!
Shipping is possible, and would need to be done in probably 2-3 separate boxes (I already have the boxes). Local pickup in the Montreal area is also possible.
Asking 700U$ or 1000$ CAN, plus shipping (and 3.5% Paypal fee if outside of Canada), within Canada EMT bank transfer (no fee) or cash in person accepted.
This price is way under what I paid, just the crossover pair was 200U$ at the time, on ebay
Thanks for looking
SB
Kit Contains:
Thanks for looking
SB
