Dynakit ST35
Ciao perdonate il mio inglese sto costruendo un clone del dynakit st 35 riscontro un problema, non riesco a capire sul pin n 6 del triodo di ingresso 7247 ci sono 52 vdc mentre la tabella schematica riporta 112vcc, grazie per eventuali consigli
Translation:
Hi, forgive my English, I'm building a clone of the Dynakit ST 35, I'm having a problem, I can't understand on pin 6 of the 7247 input triode there are 52 VDC while the schematic table shows 112 VDC, thanks for any advice
English please.
Hugo :cop:
Moderation team
This indicates that the first triode draws too much current ( Vcat= 1.8V )
Two reasons : the grid is not grounded but free floating. Check this( you could ground pin 7 to ground )
Or the tube is the 823 model, check by temporarily replacing with a ECC83
If you install a ECC83/12AU7 in the same socket i suspect that the voltages on
plate and catode is according to the dynaco manual ( 112V and 0.8V )
To be gente of the ECC83 you could temporarily disconnect the R7 and R6 resistors.
