Dynacord MCX 16.2 Console mixer Schematics
Hello. I was wondering if any of you have the schematics for
Dynacord MCX 16.2 or 24.2 Mixer.. I cant find any on the web.
The problem is that 5 channels are not working and I have low volume output.
All this occurred by the caps from the power supply shorting out.
Thank you!
From the pictures on the web, it seems a simple mixer.
Since You've replaced caps, are Your rail voltages reaching the op-amps ?
Check this first.
the +- 15 voltages work but when i connect the board.. only the +15 rail works..the problem is that i cant find the short on the -15 rail..
I'm using the Ohm meter to find the short but no luck..shows me 24kOhms
thanks!
