I have a pair of Dynaco A470 output transformers that I have not got around to sourcing the rest of the parts for an ST70 build. But I do have a handful of 4P1L that I picked up when I had a Bottlehead Smash. The Smash is gone but wondering if this parts bin combo is a possibility?
I don't think the 4.3K center tapped primary impedance would work with the 4P1L, which I have seen recommended impedance of between 2.5K to 3.5K.
Would paralleling tubes, or using 4, or 16 ohm taps, change this?
Speakers are again parts bin Goodmans Axiette II 8in, which I would run open baffle down to 80-100Hz, where 5 to 10W would be more than enough.
Cheers
Grant
Cheers
Grant
