DVI to VGA
Yes I could. I have thought of that... the only problem is that I only have 1 AGP slot, as does every mobo.... that means I would need to get a PCI card.... PCI cards aren't going to be good.... It would also need to support dual monitor...
We'll see...
Thanx for the suggestion though
Dwiel
People. Those $5 things are adapters, not converters. DVI-I has analog VGA outputs as well as ditital (like the Radeon cards). The $400 thing actually converts digital DVI signals (DVI-D) into analog VGA. That is the difference, and a big one at that.
Let me clarify this. Video cards, such as my Radeon 9500 Pro have a DVI-I output. This is a 29-pin connector.
Some of those pins output a digital signal. Some of them output and analog signal. Same connector. In order to connect it to an analog VGA device, you use a very basic cable or adapter. An adapter actually comes with the 9500Pro. If you wish to connect it digitally to a device that has a digital DVI input, you use a regular DVI cable.
The Radeon ALSO has another VGA-only connector on it. This is for a secondary display. Lemme put it this way. I have two analog VGA monitors. One is connected to the VGA connector. The other is connected to the DVI connecter via the cheapo adapter that came with it.
There are also cable adapters that can actually split the signals, allowing you to output digital and analog at the same time to two different devices.
EDIT: I just typed all that for no reason. Read this instead:
http://www.mycableshop.com/3rd_Level/Video-Flat.htm
Thanx
Thanx a lot for the help. Really clarified it for me. Not sure yet what I will go with... I might just use the s-video on my computer in conjunction with a VGA box so that I can also plug in video game consoles and things to it... anything else that supplies non-VGA signals...
Thanx again for the very helpful help 😛
Dwiel
In my current setup, I'm running an agp Radeon 8500 and a pci GeForce4 MX to connect two vga monitors and my projector's lcd pannel. Everything works great. Almost any pci card should be sufficient for just playing movies and such on your projector; however if you plan to play games on it I'd look into a dual display agp card.
Here are a few examples:
http://www.compgeeks.com/details.asp?invtid=G4TI4400-MSI
http://www.compgeeks.com/details.asp?invtid=G4TI4600-MSI
http://www.newegg.com/app/viewproduct.asp?DEPA=&submit=Go&description=N82E16814102271
