During another monemt of stupidity
If that's the cap being used in the LC series combo in the parallel woofer leg, I wouldn't worry too much. The tolerancing of the relevant driver parameters probably swamps that small error. If you want to be anal about it, you'll need to trim all the xover values for your particular drivers anyway. And if you're not anal about it, why worry, eh?
Just as a test, let's try the following.
If I take an 8 ohm speaker, resistive, and add a 2 uF capacitor which is 8 ohms at 10,000 Hz, how far down will my response be at 10,000 Hz?
If I take the same speaker and add a 2.2 uF capacitor at 10,000 Hz, how much farther down will my response be? Considerably less than a single dB, I am sure.
I realize that we are dealing with a more complex crossover here, but I think that might be indicative of what little difference it might make.
Jhovis said:
Since we're all chatty over this XO for the MBOW1, I have another rookie question. On the low pass can I just twist the 30ohm and 10ohm resistors together along with the 1.25mH and 1mH inductors...or should I connect them to a segment of wire as they appear on the XO?
JH
All the components should be hard wired together point
to point avoiding any additional wire or solder joints.
🙂 sreten.
sreten,
Thanks, you've been a very reliable font of information. BTW, I was in Castle Combe, England last spring and won a karting endurance race. My co-drivers were from England and Italy. We trounced the rest of the field. Afterward, we went back into the village to the pub and drank ale from our victory cup! I lodged at the Manor House which is the nicest place I've ever had the priviledge to stay.
jeff
Jhovis said:
I ordered 2.2uF caps instead of 2.0uF. These are Solen with a 5% tolerance (2.09-2.31) and that is out of range. This is for my MBOW1 project: http://murphyblaster.com/content.php?f=MBOW1.html
Will this be a problem? I'm going to assemble the XO anyway and if anyone thinks it is a problem, I'll order the proper 2.0 uF.
Just call or write whoever sold you the caps and tell them what happened. My guess is you can return the 2.2's for replacement.
