Dummy Load resistors
Now these are what I call Dummy Load Resistors.LOL....they are Dale 8 ohm 225 watt:devily:
Load resistors
Are they inductive?
I have a pair of similar ones and I can't use them because of
that... They are very unreliable as far as readings on the scope,
they present an inductive load to an amplifier and the waveforms
are unpredictable and not truthful.
Non Inductive Speakers?
But most speakers present an inductive load too.
So is the issue with non-inductive dummy loads is to be able to take accurate output readings?
If this is the case, are inductive dummy loads OK if you are just trying to run an amp at power without endangering your speakers and deafening the neighbors?
