The mystery is solved!
My voltmeter played a trick!
Of course not!
As long as he doesn't understand what happened, for him it's a trickThe mystery is solved!
Of course not!
Mona
Q:
All I can think of is this: his meter indeed didn't play a trick... he measured between two windings that were floating with respect to eachother...
A:I'm guessing you disconnected the wires you planned to use as a centre tap again and measured between the two?
Yes.
I just cleaned the sensors tip and waved the plugs. Than everything was allright.As long as he doesn't understand what happened, for him it's a trick
Yes, but in addition each measured value was very strange.he measured between two windings that were floating with respect to eachother
Greets:
Tyimo
Have a look at this and some of the other articles at the site:
Transformers Part 2 - Beginners' Guide to Electronics
- Power Supplies
- Dual rail supply, no centre tap
