Dual drivers and Xmax hornresp question
Hi there, I have a question about diaphragm displacement when dual drivers are used in horn response. In the schematic the driver diaphragm seems to merge as one, and the diaphragm displacement window does not indicate that I am getting a reading for two diaphragms. Going on the notion that hornresp only sees one diaphragm, can I double the Xmax limit for one driver?
E.g. If one of my drivers has a Xmax of 6mm, can i now push the enclosure design to allow for a 12mm Xmax?
Thank you all for your time. 🙂
