I installed a temporary 20K pot in place of R217. Yes at 3.3k the amplitude of the clear square on pin 8 goes to about 7v. I didn't turn higher than 3.3k though.
How much amplitude does this circuit need?
I'm not sure but it needs to be high enough to make pin 10 start producing pulses. I wouldn't let the amplitude increase to more than the supply voltage for the 4093.
I cant get it higher than about 7v. The supply voltage on the 4093 is 12v. I forgot to mention this, but yesterday slipped and messed up the parts CD4093. I then went back to the amp's original 4093. I think I might need to order a new CD4093 this time.
There should be a resistor between the output of the LM311 and the positive PS pin for the LM311. What is it?
R214. That’s a 2.9k resistor. I actually tried lifting that resistor but it did not increase amplitude to the mpsa92 emitter.
Do you have a signal generator that's isolated from the mains power (battery operated/handheld)?
I dont. I could probably use a tablet as a generator if its just for the RCAs. Otherwise everything is non-isolated. I can disconnect the RCA shield from my generator.
Are you thinking I could use a frequency generator attached to pin 8 of the 4093 instead of the LM311/MPSA92? What would be reverence? Negative rail? What would be the frequency?
Yes. Before going through any other resistor replacements/mods, I just want to try to drive a strong signal into pin 8.
You can use the added windings to generate a drive signal that floats and can be referenced to the negative rail.
Have you seen it in the tutorial?
- General Interest
- Car Audio
- Dual DA6001 muted?
