I am a newbe working on completing an ono clone.
I have a question regarding the chassis earth for a dual chassis arrangement.
Should the chassis with the phono stage be earthed in a separate cable that is connected to the PSU box chassis that in turn is connected to AC earth?
Should I have two separate earth cables from phono box one with signal earth to PSU box and one for chassis earth?
/// CF
/// CF
My preference is to AC earth ground the chassis of the power
supply and then connect the power supply circuit ground to
that AC earth ground through a bridge rectifier (so that it
conducts above .7V) in parallel with 22-47 ohms or so. Then
I attach the chassis of the signal circuit the signal ground
and see to it that the chassis does not otherwise get connected
to the AC earth.
to the AC earth.
