Dual 6J5GT can be directly replaced 6SN7?
So if project use 2 6J5GT, can I use 1 6SN7 instead?
You can even the inter-electrode capacitance's are smaller ( a good thing ) but obviously the bases are different .
All other parameters are identical except the heater current .
Yes , the 6SN7 was looked on as an equivalent electrical replacement ( at the time ) for the 6J5 as it saved a tube stage and had near identical specs.
Some might like a whole lot of tubes to light up but you cant argue with identical specifications ( apart from the base and 0.6 heater current ).
2 each 6J5 have a total of 0.6A filament current.
1 each 6SN7 has a total of 0.6A filament current.
It does not get any more equal than that.
(In a circuit with 2 triodes, the heater current is the same).
- Tubes / Valves
- Dual 6J5GT can be directly replaced 6SN7?
