DT irritation
Does any one know how to disable the auto shut off feature on BP9080x, it is most annoying as it operates frequently at low levels of volume instead of operating at no audio. The result is a loud click / thump at regular intervals. Thanks in advance!
Try to get and post schematic or service manual, otherwise it´s impossible to suggest anything.
Also write them, tell them about your problem, they might suggest something and even repair it under warranty, at some official Service center, since it IS an annoying problem.
Maybe they can either increase sensitivity or make the "ON" time constant longer, say 30 minutes.
Don´t suggest you mess with it without enough dtata because it must be a jungle of SMD parts.
And it might even be done "all in Software".
