Did you see a rail-rail signal on the input of the inductor?
What's the rail voltage in this amp?
Ok I found a burnt resistor by the audio driver board replaced it now I get -167 volts across the speaker terminals.
Any ideas what might cause this ?
You're going to have to wait for someone with a diagram of a similar amp. I have no clue what resistor you replaced or what driver board it uses.
Does this amp have a bridged output?
- General Interest
- Car Audio
- DS18 Amp
