Driving KT150 PP
This datasheet is more complete:
https://frank.pocnet.net/sheets/084/k/KT150.pdf
These are the loadlines for UL 43% connection at 400 V:
461548d1422209327-kt150-curves-sofia-v2-bmp
So expect to need at least 150Vpp to fully drive them at 600V.
Hi Gerrit,
Well, this afternoon just looking at it, now with the 3/2 power law and the plate dissipation:
The tube has 70 W of plate dissipation, so at 600 V you will bias around 82 mA.
600 V is 1.5 times the shown 400 V, so all voltages need to be increased 1.5 times and currents by anfactor of 1.84 (that is 1.5 ^3/2).
So the same point will be in that plot at around -62 V, that will become -93 V.
So it is 186 Vpp neede to fully drive the push pull into saturation. That is 44 Vrms. Consider to use no more than 47 kOhm as grid leak, it is safer.
I would also consider to use lower voltages, being 600 V the maximum limit in UL.
