Driver size query
diyAudio Member
Joined 2007
I recently purchased a couple of well made boxes thinking that I had suitable drivers in the stash based on the sellers description.
I do but only 2 of them and they are old model Tandy drivers more suitable as midrange not as woofers or subwoofers.
Anybody know of a driver that has a cut out of 240mm and an external driver size of 270mm?
I'd like to be able to use these well made boxes if affordable drivers are around. Asking here while I search though sites.
Australia so my options are limited
Looks like any of the Dayton 270 series will fit and the SD270A-88 is in the ball park for my budget.
Any feedback on its use as a woofer or sub-woofer?
Boxes are built for two drivers in each box so they'd be wired as dual 16R in parallel each box and each seeing a box of ~35litres
Woodwork has never been my strong point but a new baffle could be easily done. The Dayton linked does seem to model reasonably well in these boxes tho. Which is why I am awaiting on any feedback from folks who've used them before making a purchase decision
Reactions: stv
Well the Daytons are $149- each, which I suppose is cheap these days.
I will have to sell a quad of the Jaycar 10s tho.
@zman01 the recommended box size for the drivers https://www.theloudspeakerkit.com/dayton-audio-sd270a-88-10-dvc-subwoofer
Is that volume so my WAG is that these were the original drivers in these boxes.
Boxes cost me $50- and fuel but it was a nice day for a drive
You are ok with a sealed cabinet and tuning of F3 @ 52 Hz (with suggested box size as per the link)?
What is F6 and F10 like?
I have used the Dayton RSS265HF-4 which I like a lot.
It should physically fit with a 266mm OD, a 235mm cut out and a 248mm mounting bolt circle.
They are about $170 each here in the USA for a quantity of 4.
The physical fit is always a challenge because every manufacturers 10" driver is actually a slightly different size.
The cabinet volume seems close to the recommended value of 0.9 cuft for a sealed box with an F3 at 45Hz.
As for the wiring, one option besides the traditional series / parallel voice coils, is to add another set of binding posts so you can wire each driver separately to it's own amp channel.
Best success.
You need an account to see units and prices and you can't get an account opened without an ABN. You do know that WES prices are listed GST free and when you add 10% to that you get the same price as at LSK, one business being the retail sister of the other
