Hi Guys,
The PRV audio waveguide seems to be a good candidate and i'm very keen to start my own attempt at a small synergy horn.
Waveguide : https://www.parts-express.com/prv-audio-wg35-25-b-1-90-x-60-abs-waveguide-2-3-bolt--294-2892
Tweeter 1 :https://www.parts-express.com/peerl...c90-04-1-dual-ring-radiator-tweeter--264-1014
Tweeter 2 : https://www.parts-express.com/peerl...pression-horn-driver-2-4-bolt-8-ohm--264-1420
Woofer : https://www.parts-express.com/dayton-audio-dc130b-4-5-1-4-classic-woofer-speaker--295-307
i guess i'm still torn between using:
1. Ring radiator tweeter
2. Compression driver tweeter
3. 1.5 inch full range speaker
Is the dayton 5.25in woofer suitable? It has Qts 0.35, motor is not too strong at BL 4.89.
i guess matching all the components are important to distribute the cost and keep the chains in the link equally strong, as opposed to having an obvious weak link in one component. It seems the woofers would be hard pressed to keep up with the Tympany CD?
