Driver placement & enclosure design help
Help!
Need - THREE WAYS WITH CROSSOVER
ENCLOSURE SIZE - EXTERNAL - 40"x13"x10" (HxWxL)
MDF - 1"
What if i add another 8" woofer, please suggest.
Please see the setup detail
RMS INPUT POWER W 100
FREQUENCY RANGE Hz 90 / 14000
NUMBER OF WAYS - THREE
NOMINAL IMPEDANCE 8
CUT-OFF FREQUENCY Hz 290 / 28 K
SENSITIVITY db
TWEETER TYPE - Piezo
MID RANGE TYPE - 5" papercone
WOOFER MID BASS TYPE - 8" Plastic cone
TWEETER MAX DEPTH mm 13
MID BASS MAX DEPTH - 40mm
WOOFER MAX DEPTH - 75
Application - stereo(audio) , rock, classic.
(AMPLIFIER - TEAC AG780)
Help!
MDF - 1"
NOMINAL IMPEDANCE 8
SENSITIVITY db
There is clearly not enough information on your post for any one to help:
1) Get rid of CAPS, no one likes em.... your thread will be ignored.
2) You sense of urgency is not in line with others, this forum is not a paid subscription so while you will get helped, you need to set your own expectations in check.
3) Get rid of irrelevant info what amplifier u are using unless people ask because at this point it is cluttering your post.
4) Please provide the drivers T/S parameters or perhaps make and model.... saying that it is plastic wont help anyone...
I wish you a happy and productive search.
